Pedal box seal question
tdskip
For a Bugeye which of these are needed? My car as bought only had #25.
Anyone have a picture of how it should look?
I don't have either.
Only number 25 and you can make it with a bit of 90 lb roofing felt.
My '66 Sprite MkIII also has #24. The pedal box has a couple channels welded on that retain the foam seal #24. I'd always thought that the pedal boxes and MC's were the same for these cars, but if you pedal box does not have the channels made to retain the seal, perhaps seal #24 was added later. I used some pickup truck/camper shell gasket material to make #25, but purchased #24 from VB or Moss. It's just a piece of 1/4" thick black foam with a couple slits for the pedals. Easy to make if you have the material.
