Hi my question is, on a 1975 US TR6 can you remove a brake PDWA valve piston on the car.
My PDWA valve is leaking through the switch so I need to stop this.
My options.
1: do nothing other than cap the switch with a 3/8 UNF bolt and copper washer, my worry about doing this, if one side of the piston rubbers fail completely would this stop the equal pressure keeping the piston central and possible only having either the front or rear brake circuit working, I do not know the travel of the piston left to right.
2: remove the piston and re rubber the piston, this would be the safest option keeping the braking system to US spec.
I have read about the problems removing the piston, can this be done on the car, I have not yet lost my brake pedal but it must be drawing in air.
I am sure someone must have tried this, if you cap the switch and remove the piston bore cap and press the brake pedal, will this eject the piston.
3: if the piston is removed has anyone not put the piston back in and run the car with one brake circuit like UK cars, I am worried that the 2 circuits could have different pressures from the brake master cylinder and cause all sorts of problems.
4: has anyone done away with the 4 way PDWA brass body and used 2 brass straight connectors to create a front and rear brake circuit.
Thank you for any help Mick.
My options.
