TR3driver
Great Pumpkin - R.I.P
True. But the same thing is true of the master cylinders, and those seals move all the time. The PDWA seals should last much longer, since they don't normally move.Brosky said:There is brake fluid in there if the seals leak
The switch is not designed to hold pressure at all, it's not internally sealed. So, if the seals in the PDWA leak, you can expect to lose brake fluid.
