BlueRidge2
I recently read a how to article on pcv valve installation on a BJ8. If I remember correctly it was by Fine Spanner.
Since I have no power booster to pull vacuum from I will be pulling it from the intake manifold. Can I pull the vacuum from 1, let's say just the rear manifold or do I have to pipe all 3 together in a common plentium? If I do pull from one will it affect carb adjustment or balancing of the carbs? And I noticed fine spanners pcv valve was horizonally mounted, would it function better in a vertical postion. Thanks Bob
