Spridget64SC
Often with the A-Series engines, I find that the sealing area on the rear main bearing cap and the triangular seal flange on the block are worn from the crankshaft flexing. This flexing is usually caused by a bad bearing somewhere in the engine or a badly worn pilot bushing leting the clutch disk and input shaft woble. Machine shops often will "Polish" the scroll area of the crankshaft so it looks nice to the customer. This further increases the "sealing" clearance to the crankshaft. I always write on the tag going with the crank, not to polish the scroll seal area. If you find the rear main cap and the block flange grooved, it will be necessary to line-bore the block. Good machine shops should be entrusted with this task as this operation loosens the timing chain just a bit. Cutting the cap too much will loosen the chain even more. Also, there is a gasket that goes under the block flange.
T-J is on track. I think your issue with the leak is in the rear main area. One can also increase the drain holes size by a 16th of an inch. And, machining with a ball mill inside the groove in the main cap can increase the area for oil to pool and then drain out the holes. Machine about a 3/4" slot to the edge of the main bearing and the length of the two holes.
If you need a replacement triangle plate or just the plate gasket, please advise. I have plenty of these from broken race engines and 30+ years of accumulation.
HTH,
Mike Miller
HTH,
Mike Miller
