Rut
I just had to do it! I installed a 1/8 nipple in the intake manifold and piped in a PCV from the oil separator. I have a Weber carb on a Pierce manifold and there is a boss just below the carb for tapping. I fired up the engine and it didn't want to idle (no surprise) and with the help of a little choke ran at about 2000 rpm. The rear end leak stopped completely! About a minute or two later I was killing every mosquito in the neighborhood! I had more smoke coming out of the exhaust than a barn fire. I disconnected the hose barb to the manifold and held my thumb over it and she settled in to a good 900 rpm idle and the oil flow returned. I also had oil bubbling out of the separator up thru the pcv. I must have applied a little too much vacuum, but it did solve my oil leak problem. Now I need to figure out how to regulate the vacuum so the engine will idle, won't suck up oil, and the rear leak will stop or slow to normal 1275 standards. Any suggestions out there?
Thanks, 'Ole Smokey'
