Paul [apbos] how did the rear fender removal go?
apbos
It was an ugly 4 1/2 hour job! Had to grind off all of the bolt heads on the trunk and broke on both sides the rear bottom bolts (how do I repair them ???). Also had to grind off one bolt head at the lower front of the left rear fender. All the rest came loose with penetrating oil. A big problem was the sealer (dum dum?), which covers the bolt heads and had to be picked of to get the 7/16 wrench on the bolt. How they could put these cars together rapidly at the factory is a mystery.
Paul
P.S. How goes the floors?
martx-5
Re: Paul [apbos] how did the rear fender removal g
apbos said:
... and broke on both sides the rear bottom bolts (how do I repair them ???)...
I assume that you are talking about the caged nuts at the very back of the fenders (three on each side) that are impossible to get to without cutting the rear valence apart.
What I did was knock the caged nut out of the holder (yes it will lay inside forever), and then welded on these weld nuts from McMaster. I had to drill the holes slightly so I could insert the threaded section of the nut. It worked out very well.
apbos
Thank-you Art!
That should make the repair a lot easier. What about drilling a drain hole to get the nut out and then sealing it with a rubber plug? I've also got some questions on your mods (alternator and brakes) that I wil pm you about.
Paul
martx-5
I don't see why it's neccessary to get them out. With all the other noises going on in the TR3, the occasional rattle from one of those nuts way back there will never be heard. I certainly haven't heard them, and I have two of them rattling around on each side...four altogether. :laugh:
BTW, when you PM me about the other issues, give me your address and I will send you a bunch of the weld nuts...on me. I have so many left over. I sent some to someone else on the forum, so I'll extend that courtesy to you. :cheers:
TR4nut
Doesn't the valance have plugged drain holes anyway? I was thinking those loose square nuts could come out that way. Thanks again to Art on the method, its my plan of attack on the bottom nuts that are the problem on my car.
Randy
Boink Sir Paul's latest video... with Frogeye! Spridgets 6
S Paul McCartney Drives a Bugeye Spridgets 1
3798j Paul Newman Movie Racing 5
Mickey Richaud Hey, Paul [Brosky] - Triumph 2
Pythias Paul A. Gasket? Spridgets 2
Gerard April 10th Memorial for Paul Asgeirsson Spridgets 0
Gerard Paul Asgeirsson Memorial page Other British Cars 4
Gerard Paul Asgeirsson Memorial page Spridgets 1
B Paul A's Morris is on the block Spridgets 5
B Paul A's Morris is on the block Other British Cars 9
T Wedge Paul - driving impressions of TR8 vs your '6? Triumph 13
T Paul - any seat Latests? Triumph 3
T TR2/3/3A Paul - any Latest[s] on the TR3? Triumph 3
DNK Hey Paul Triumph 12
T Paul - did you change any wiring for the Bosch? Triumph 3
roofman Still another for Paul, and in his backyard. Triumph 13
DNK Another one Paul Triumph 7
DNK Hey Paul, Still Available Triumph 2
DNK Paul- You are getting sleepy, Very Sleepy Triumph 10
BobbyD Dale & Paul - Separated at birth Triumph 15
T Thanks Paul Triumph 1
BobbyD Insurance Pictures...Thanks Paul Triumph 4
LastDeadLast Paul Newman: 1925 - 2008 Triumph 9
swift6 Hey Paul, you need this for your office! Triumph 1
T This ones for you Paul Triumph 9
T Wedge Paul - your TR8 is ready. Triumph 7
T Perfect timing Paul/Alana Triumph 4
T OK Paul, winter quiz time Triumph 5
DNK Hey Paul!!! Triumph 6
tomshobby Pictures For Paul Triumph 11
tomshobby head studs, Paul Triumph 5
T Paul's Tripleta Up-date Triumph 2
T Cheer up Paul, Triumph 8
kodanja Thanx Paul! Triumph 1
W 1986 Paul Banham Sprint [Bugeye replica] Spridgets 6
T Paul,Bill, et al- Crypt Car back up posting Triumph 9
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
Y MGB How did become such a mess up???? MG 2
dougie Did Big Healey Drivers Go Soft? Austin Healey 8
V MGB Mystery fastener from '66. Did I miss something? MG 6
mezy Heres one i did. Other Cars 9
algot1901 How did people in the 1950's manage to fit in the Prefect???? Other British Cars 16
BoyRacer Did BN2s have adjustable steering wheels? Austin Healey 5
jlaird MGB Don't post like I did 10 years ago. MG 7
AngliaGT MGB What Did You Do on Your MGB Today? MG 6
JPSmit Honey, did you hear that clunk? Other British Cars 0
B TR4/4A What did I do wrong? Triumph 19
Elva164 Finally did another onboard video! Racing 4
Jim_Gruber When did Mini’s get so expensive Spridgets 20
J TR4/4A Did my own carpet Triumph 16
