Passing the smog test
Yellow B
I recently moved to California with my '77 MGB. The stock Zenith-Stromberg has been replaced with SUs, and I am worried that the car wonโ€™t be able to pass the smog inspection so I can register it in California. Does anyone have experience getting a B with SUs to pass the California smog inspection or suggestions to offer?
Deleted member 8987
Unless something has changed....it won't pass...ever. Because, visual inspection if first. Has to have everything it came with...exactly.
The State has never cared about tailpipe if the visual don't match. You could invent a carb that gave 60MPG and zero emissions...and it wouldn't pass.
We've had a few here who tried. Most gave up. Do NOT start the process until you are prepared...I think there is a time limit in which it must pass....or be scrapped.
Stewart
Only choices you have is to either convert it back to stock with all smog equipment or if your lucky find someone who's selling the moss carb legal fuel injection and swap to that after reinstalling the smog equipment. Once you get it back to stock then you have to get it to actually pass smog. If it were me I would be really tempted to convert the stock zs carb into a throttle body using patton machines efi setup. https://www.pattonmachine.com/TBI-Customer-Cars.htm Looks stock enough to get through the visual and should pass the dyno without much issue.
No time limit on passing though you may have to non op the car till you get it figured out.
Deleted member 8987
Last guy on these forums with a modified Spit told us once he started the title transfer, there was a specific time frame to get it to pass or scrap it.
Then, he hasn't told us what else...exhaust and intake manifolds, cat, smog pump, air injection, factory air cleaners, what else?
PAUL161
Not what you want to hear, but it might be more cost effective and a whole lot less aggravation to sell the car to a non California resident, then purchase a smog legal California car. PJ
Deleted member 8987
as long as you don't start the process and let dmv have your title. Once you do that, game over.
Grantura_MKI
Would reg out of state and keep your fingers crossed that you donโ€™t get caught. Late Bs will have this problem forever, as they where not that good from the factory in California guise.
If I really wanted a B, would sell the one he has and purchase a MKI.
True about the DMV....once they have your paperwork, or vin number you are doomed!
Y
Yellow B
This is all very sobering--and disappointing. But selling the car out of state and buying something that will pass is probably the most realistic option. I thank you all.
Deleted member 8987
When dealing with CalDMV and CARB, truth is far stranger than fiction.
mrv8q
In CA, you will want a pre-โ€˜76 vehicle. You missed it by that much, two years.
Platinum
While planning to escape western Pennsylvania winters we had two choices; California or Florida. Had offers in both, looked at cost of living vs. wages and vehicle requirements/restrictions. Florida was a no-brainer in our case.
PAUL161
South Carolina is pretty much in the same category Doc. PJ
skinsgamer Passing Cali smog Spridgets 6
77_MG_Midget Issues passing SMOG testing Spridgets 2
HealeyRick Passing of Marty Jansen Austin Healey 10
N Passing of "Bic" Healey Spridgets 3
Tr3aguy Triumph Enthusiats Passing Away Triumph 12
TRclassic3 Passing of a Triumph friend Triumph 0
lbc_newbie Passing of PaulA Spridgets 5
lbc_newbie Passing of PaulA MG 3
M Passing of a friend... Triumph 6
R DEQ testing/passing & exhaust gas analyzer Spridgets 7
bugimike Still more sad passing - TVR TVR 18
M Passing emissions to get a Collector Plate! Triumph 4
M Smog pump and alternator brackets Spridgets 0
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
A Wondering about buying a 1976 mg midget will it smog? Spridgets 8
L Spitfire Newbie amateur mechanic needs help w/California smog equipment Triumph 6
C TR6 Need to pass CA smog, Los Angeles Triumph 4
B MGB Calif. smog questions MG 29
T Wedge Riddle me this guys | TR8 SMOG test issue Triumph 13
J MGB Smog test fail MG 11
J Wedge Modified TR-8 in California...I need help to pass smog...HELP!!!! Triumph 25
Bob Claffie MGB MGB smog control ???? MG 12
rlich8 TR6 '76 TR6 - De-Smog or Leave? 19k original mile car Triumph 29
P E Type V12 PCV & Smog systems Jaguar 8
1 Smog/Emissions question MG 8
SCguy Wedge My TR8 failed CA smog! Triumph 9
pakiwi Removing Head with Smog Equipment Spridgets 8
B New Proposed California Smog Legislation Triumph 5
2wrench TR6 '74 TR6. Let's talk about disconnecting smog stuf Triumph 29
neilh passed CA Smog - now it won't idle! Spridgets 3
ncbugeye Smog oil-filler cap Spridgets 3
SCguy Wedge My new TR8 and CA Smog [Latest picture] Triumph 26
S Smog? Mine's a '76? Story of My Life... Triumph 9
G smog equipment MG 29
drooartz Smog head 1275 question Spridgets 33
G Is there a procedure to remove the smog equipment? Spridgets 1
H Spitfire My Spitfire declared smog exempt! Triumph 0
6 MGB-GT De-smog'in the 71 B GT help? MG 25
S Smog Equipment Removal MG 7
Nunyas Smog Pumps... the Op check... MG 2
TNMGB What smog stuff am I missing here? MG 13
MattP Smog pump question MG 3
Bret D-Day in Poway - Smog Test! MG 9
A Removal of the Smog Equipment MG 39
RobSelina Removing all smog equipment and my heater Spridgets 13
M Removing smog devices MG 5
MrBlueSky Wedge tr8 air/smog pump?????? Triumph 6
Bret Smog Test Round #2 - A Happy Day! MG 0
Bret Smog test: Round #1 MG 20
