Well I have the gap at the top of the passenger door. I have seen this gap before on other cars and remember someone on the forum welding metal to one side of the problem, either door or the fender and the one I am thinking about they welded the door. On this one, I want to either weld a piece to the fender or maybe even fold out the fender metal right in that area by rolling the metal out. It looks like someone pushed and rolled some extra metal under the fender so there is material there to do it. My thoughts are that if I try to fold the edge out the metal will tear and plus lift up or whatever and cause more damage, but again that area is damaged anyway and will need putty. So if I heat it up would rolling out it be easer? OR is welding a round 1/8 something there best? Thoughts are needed!!!!
Hi Guest!
