TR2/3/3A part numbers for tr3 clutch
sp53
Does anybody have the part numbers for the clutch and pressure plate to fit a tr3? Perhaps the Borg Warner numbers or another large supplier.
Sp53
I have a brandy new in the box clutch and pressure plate from moss motors, purchased last fall, turns out I do not need it. I would be happy to sell it to someone who could use it. 60 cents on the dollar. Tom
The clutch disc I just installed -- brand AP or 'Automotive Products' is p/n HB9713Q. This is the Moss part... I don't know if you can actually get a clutch disc branded by Borg & Beck.
Do you actually need a new pressure plate? I replaced mine because the old one broke (that was the failure rather than a worn disc) but as I understand it that is a rather rare situation as these guys (the 3-finger type) are pretty robust.
Oops... I just figured out that AP *is* Borg & Beck. Doh!
Hi Tom I am definitely interested. How do you want to proceed? You can call me in Washington State at 253 475- 1133 or you can use email Sp53 @u.washington.edu
Sp53
I tried email I don't think it worked. I will check the boxes this weekend and let you know excactly what part/ part numbers I have and we can take it from there. Tom
Hi Tom, yes evidently the email did not go through. Try again and see what happens, I checked the address and it should have worked. If you want you can post your address, and I will try from this end.
Sp53
Aloha Sp53,
A few years ago I bought a Borg & Beck pressure plate with cover from Moss for my TR3. Their part # was 593-000, I found the box yesterday cleaning my garage. The numbers on the box were: GCC127
Borg & Beck
NHA2520
Cover Assembly 228mm
LL42J
GB
Hope this is helpful.
Safety Fast,
Dave
This is what I have in the box, parts were ordered from Moss.
Borg & Beck disc part Moss part 4-207 delphi (tm) part no NHB9715 description driven plate 229 mm.
Release Bearing/ throw out bearing Green Bearings part # CB1087. Moss part 4-352
Borg & Beck pressure plate, marked as follows 4LCEG0213a and fingers marked No 51022,
all of this was purchased from Moss as clutch kit moss part 593-055.
Tom
Hi Tom I am kinda confused on the part number. I looked at the Moss online catalog and found a part number 593-050 for tr2-4 that was a N/A kit. But let me get home and look at the Moss's hard copy because I have found some editorial problems with the Moss catalog that is on line before. In addition, is the clutch a delphi brand or Borg Warner brand? And what is your best price for the lot? You can email me at sp53@u.washington.edu
sp53
