Parking Lights
wsm
The right side parking lights, both front and rear, have all gone out on my '74 Midget. I've checked the bulbs in the front and they are fine. I assume that this means there is a common switch or circuit for all of these lights, with a short, blown fuse, etc., but my wiring diagram is sketchy and I'm not experienced enough to pinpoint the problem.
Any thoughts?
Thanks.
ChrisS
I have a PDF wiring diagram for a Midget Mk. III, North America, Neg. earth, G-AN5-138801 onwards (1973-74), but it is too large to post here. I can email it to you if that helps. Hopefully this is better than what you already have. As with any electrical problem, be methodical and always check your grounds.
wsm,
check and clean the fuse box connections. the bottom two fuses should be your running lites. check those fuses as well. Do you have headlites? Brake lites? The other possibillity is your switch in the dash.
mark
W
wsm
Mark, yes, headlights, breaklights, turn signals, and even the parking and running lights on the LEFT side of the car are all working properly, just not the right side parking and running lights.
As far as I can tell there is just one fuse box (under the hood) containing 4 fuses. All fuses are ok and the connections seem clean. But, I did notice that the fuse box connection furtherest forward and on the driver's side has nothing connected to it. Could that be the problem? But, if this was the problem, it seems that none of the parking lights should be working. Thanks for any input you can give. I'm just learning about this stuff.
Thanks,
WSM
Is this something that just happened or are you sorting out a car you just got?
I just went and checked mine. there should be a red wire with green stripe on one of the fuses. this is the parking lite feed. Should be 12v with the switch on. On the other side of the same fuse, two connectors with two red wires each (four wires) one set on top and one set on the bottom. these are your left and right feeds. for the record my car only uses three fuses. one slot is empty. fuse blocks have been known to go bad. if you suspect this try using an inline fuse.
hope this helps
mark
W
wsm
Yes, this is something that just happened. I've had the car about 2 months, and the lights have worked until now. Also, just a few minutes ago, while driving, I lost the tachometer and turn signals! The flashers and headlights still work fine, but no tach and no left or right signals.
Could this be related to the right side parking light problem?
wsm
sounds like you need to start going over some wiring. i would be willing to bet you lost your brake lights also. the trunk is a good place to start looking for bad wires. Sometime loose items bouncing around in the trunk can cause some trouble with lights. I loose my tach, fuel gage, turns and brakes sometimes when spiritedly driving. usually it is just the fuse that blows.
i would say probably not. its best to fix one thing at a time. with electrical you need to be methodical about tracing it out. do you have a test light?
mark
W
wsm
Not yet, but I'm ordering one now. Any other tools you'd recommend for electrical projects?
Thanks for the tips Mark.
wsm
well that pdf diagram Chris offered would be a good one to have. A kit of connectors and crimpers. some wire, electrical tape, and patience?..lol a tube of rtv, i use it to fill butt connectors before i crimp them, helps to keep them clean and somewhat water tight.
more than happy to help
mark
Bugeye58
WSM, I would also suggest a simple multimeter. It doesn't have to be anything fancy, just one capable of doing resistance and voltage measurements. Should be easy to pick up for under 20 bucks.
Jeff
ChrisS
You should have it. Let me know if you need a different one, I think I have them all up through '74.
There should be a red / green wire going to the two fuses Mark mentioned, the left lights are fused to terminal 2, and the right are fused to terminal 4. There should be two red wires leaving terminal 4, one for the front and one for the rear. If you have left lights the switch is good, so it is either the fuse, fuse block, or wiring. Remove the fuse, check for continuity to see if you have a good fuse. Even if the terminals look clean, get a small wire brush and clean them, reinstall a good fuse, turn on the parking lights, make sure the left lights are on, if so check for power on both sides of the fuse at the blades that hold the fuse as well as the terminals (mine had a break between the blade and the terminal). If that all looks good, pierce the insulation of the red wires leaving terminal 4 and check for power. This is a last resort because it creates a corrosion point in the wire insulation and can become a weak point later, but at this point the lights don't work anyways. Let us know what you find and we'll go from there.
spritenut
On the 74 there are 2 fuses for the parking lights up under the dash sort of behind the glove box.
They are inline fuses, follow the red wires.
K TR2/3/3A More electrical....parking lights?... Triumph 2
Patrick67BJ8 1967 Phase-2 BJ8 - Front parking & turn signal lights alignment Austin Healey 8
RickB All 4 parking lights dead, fuses all good? Spridgets 6
B How to install tail and parking lights?? Austin Healey 10
19_again bright parking lights MG 6
V 1969 Mini Parking Lights British Motor Corp 6
fmichaels 67 parking/turn signal lights Spridgets 8
10musketeer Hmm. Parking Lights Spridgets 4
Bruce Bowker Parking lights Other Cars 12
D TR2/3/3A wiper motor parking? Triumph 17
TomMull TR2/3/3A Parking brake: Lesson learned? Triumph 8
D Parking Brake Adjustment Austin Healey 2
M Windscreen Wipers Parking Spridgets 4
tr6nitjulius General TR TRIUMPHest 2019 Register# Reserved Parking Space# Triumph 0
J For Sale Triumph tr6 tr250, tr5 parking brake improvement kit Triumph Classifieds 1
G TR4/4A Front Parking Lamps Wiring Question Triumph 5
S TR2/3/3A Wiper Motor Parking Question Triumph 8
TomMull TR2/3/3A Parking brake cable length Triumph 3
B Mini Windscreen Wiper Parking British Motor Corp 3
T TR2/3/3A wiper motor parking Triumph 7
T TR2/3/3A TR3b parking lamps Triumph 2
wingsandwheels TR6 TR6 wiper motor parking Triumph 1
T T-Series TF Parking Brake Disassembly Advice Needed MG 2
O TR2/3/3A TR3 Headlite Trim Rings and Front Parking Lite? Triumph 10
JPSmit Parking garage spot - REALLY lousy pics Spotted 6
J TR2/3/3A tr3 notchy steering in parking lots Triumph 12
PatGalvin Parking Brake Rebuild Triumph 5
Brooklands Seen in the public parking garage in St Augustine Jaguar 4
Morris OT: Spent the night in a parking lot... Spridgets 2
tweety Parking Brake Adjustment Spridgets 3
M Wipers parking in the Up position Spridgets 11
D Front parking lamps and side markers? Triumph 10
Newkie Parking and Headlight problems MG 8
PeterK Well, the parking brake works ... Triumph 12
Dadandson Adjusting the Parking Brake Spridgets 12
tony barnhill Harbor Freight Parking Lot Sale... Restoration & Tools 27
Aeroken Parking Brake Cable Triumph 6
NutmegCT TR2/3/3A Parking light fun - TR3A Triumph 38
jjbunn Windscreen Wiper Parking MG 10
Russ Austin Wife's not happy, No parking space! Triumph 8
J Hand brake/ Parking brake MG 6
J Parking lot races Triumph 15
A parking break? MG 2
C Parking Light/Tail Light Problem Triumph 5
zoohow TR2/3/3A lights in series Triumph 2
tahoe healey Wiring Diagram for Fog Lights Austin Healey 12
Overdrive45 Stalling at Traffic Lights in Hot Weather Austin Healey 20
Jcape Lights Spridgets 2
A 100-6 Brake Lights Austin Healey 2
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
