Hi Guest!
twas_brillig said:- I'm thinking of getting the steel sheet metal acid dipped and zinc-phosphate coated; I'm kind of scared to even touch the doors due to alignment concerns. Paint stripper and sanding for them and the rockers.
- get the insides of all the panels painted
- reinstall the fenders, loosely
- deliver the car with hood and trunk lid separate (or however the shop wants it) along with VISA card and first born male child
This is a really simplistic view of a long, detailed procedure - but is it generally the right direction?
Thanks,
Doug
Randy Forbes said:Whenever I have to remove a (hinged) panel that I want to go back in the exact same position, I drill two (2) 1/8" holes through the hinge (or mounting plate, depending on application) into the body below.
Upon reassembly, use a couple of loose 1/8" drill bits to insert through the holes, realigning before tightening everything back up.
HealeyRick said:... "The only stuff that works is the stuff that will kill you."
