I traveled to the American blasting Co yesterday to see what it costs to blast my frame and prime it. They had a 100 frame there they just finished. The cost for the blast was $1,500. which seems good to me. Anyway, my plan was to have the frame delivered from the welder to the blaster, have it blasted, primed and then being it home till I retire. Whenever that is. I was told that I should not do that. The primer hardens so much sitting that paint will not stick without sanding the whole frame.
Is that true? And if true what should I do if my plan is to delay the restoration for awhile?
He also said that often after blasting the frame has to go back to the welder for hidden work, then back to him for more blasting then reprimed.
If the answer is to go ahead and paint the frame before I delay the restoration, what kind of paint are you guys using?
