Tr3aguy
I have questions about paint. I have used a few products and want to make sure I will not have any issues when I get to the final stages on paint.
I used a Spies Hecker acid etch primer on the panels that were acid dipped and neutralized. They have been inside now for about 10 months. I want to seal them till a later date.
The body was media blasted and covered with a PPG dp50 lf epoxy primer.
So here are the questions.
1) Is the PPG over the Spies Hacker good for sealing, is it ok? What to do for prepping the surface?
2) If I grind away areas for metal replacement and welding what should I use to protect the area after the work? I do not have a spray gun so could I use rattle can stuff to protect?
3)Will I need to just sand for Top coating or does it take more prep work?
4) If I need a small amount of body filler in spots will it bond on top of the PPG primer?
5) Best place to purchase paint at a good price?
