Well I did some painting in my homemade crowded paint booth. The good thing is I am able to paint a panel in house because we are in the rainy season for a long time, months, and going outside is not going to work, Seattle area. One problem I had was I divided the apron into segments so I could envision the apron in smaller detail rather than looking at the whole thing and being overwhelmed by the size, and not being able to concentrate. The bad part is one of the markers I used was a very old one that said permeant marker and meant it. The lines blead through no matter how much primmer I put on. I sprayed the area 4 times with the paint knob turned out 3/1/2 times. The line would be gone then in a few minutes it would bleed though again. Thank God I only used that marker twice on the bottom to designate where I was going to stop with the glazing filler.
I used a piece of ¼- 5 layer plywood cut into an inch strip and clamped it under the headlights for a straight bench mark and then walked it down to the mouth of the grill. I recommend using that technique because I could see each area left then right in small rectangles. In addition, I drew a center line then walked that off also. So my old carpenter days came in handy again.
PJ and John made me post
steve
steve
