G
While sorting out an electrical short this afternoon, I removed my three door switches and discovered that they were pretty cruddy. I decided to clean them up and saw where the rust had cut the metal pretty good. Such a fine little part that even a wire brush wouldn't get inside. And too fine to use a sand blaster on. Well, I remembered that I had a very old Paasche Air Eraser stored away and rigged it to work off my compressor. The Air Eraser is a micro-fine sand blaster that uses dried apricot seed dust as an abrasive. They are used by archeologists to clean up old artifacts. First cousin to the Paasche Air Brush used by nearly all the air brush artists you see in the mall. (Don't even ask what I am doing with this thing.) That little jewel will micro blast the smallest part and bring it right to the metal, rapidly working in a work area about 2 mm wide. Painted all three with some Krylon (even though I think they are supposed to be body-coloured) and will have essentially new switches. Oh, and I found the short, a purple-wire light socket was out of it's holder and rubbing against the body. The Air Eraser is especially good for us OCD types that like things right....
Bill
Bill
