TR3driver
Great Pumpkin - R.I.P
On my 3A, it didn't seem to make much difference; either when I was having serious overheating problems or after I got them solved (by having the radiator recored with a modern Modine core).Ken_McGuire said:Because it still heats up at stoplights, I'm wondering if maybe I should restrict water flow through the bypass like I've seen some of you do with the 3/4" pipe cap with a hole drilled in it. Thoughts? Will this help more?
But on the TR3 with a stock-style radiator it did seem to make a noticeable difference. I'm guessing it depends on how much resistance to flow the radiator presents at idle rpm.
BTW, I used a 3/16" hole in the bypass restriction, plus a 3/16" hole in the thermostat to ensure there was still enough circulation with the thermostat closed. Might not be necessary, but I felt safer that way.
Another alternative is to buy one of the reproduction 'sleeved' thermostats. These work like the original thermostat, with a sleeve that moves to restrict flow through the bypass once the thermostat is fully open. But the thermostat used is a modern "wax pellet" design, so doesn't suffer the flaws of the original "aneroid" type.
Used to be you had to buy these from one of the Jaguar sites, but I think Moss carries them now (still at a Jaguar price, though
