Hi Guys,
Thanks for all the help with this overheating or whatever it is. Ok, this is what I did tonight, put in a 60 degree C thermastat, I have the bypass plugged with a 3/4 copper pipe cap with a 3/16 inch hole drilled in it. Also the thermastat has a tiny relief valve to eliminate an airlock. I still have the old cap 4lbs, new one on order from moss, 7lbs for tr-4 long neck rad. The car is a 57 but has a tr-4 engine and drivetrain. the qauge reads in Celsius and maxs out at 100C I did not know about the Voltage stabilizer, I have to find the old link and see if I can make one. The car did have the mechanical temp guage but it was long gone when I got the car. Anyway, the engine will idle fine at a little over 70C but as soon as rpms are increased the temp gauge maxes out and the rad cap pops open and bleeds off some water. I checked the thermastat housing temp with IR thermometer ($16.99 at harbor) temp read 63C, then 71C, then 80C, the head readings were 78, then 80 and 90 before I shut it down. I guess I need to put the new rad cap on and try it again. I added Baking soda and let it get hot again, opened block drain, had to poke coathanger in the hole to get it flowing but claer water came out, the radiator drain valve was clear and the water was clen. Checked the hose from the rad to the water pump, it's clear.
