TR6BILL said:Dale, try ditching the antifreeze and going straight water.
And then in 10 years, the inside of the engine block will look like mine was, totally plunged up with rust and other crud. The water passages between the head and block on the 1st cyl was about 75% plugged. As a result of the higher heat there had been incredible wear on that cyl. We had to bore it out from std all the way to 0.6 over to get it straight again.
