Ok, kind of weird problem. The herald seems to be overheating at highway speeds. Around town, stop and go traffic it is doing alright.
As far as temperatures, the engine is no boiling over, but it runs much higher on the highway than at low speeds, (I measured the temperature at 90C)
Clearly it is not a problem of lack of airflow considering I was driving at nearly 70mph, engine is properly tuned, dizzy just came back from Jeff at Advanced Distributors and is set at 13degrees BTC w/o vac, and the fuel mixture is a bit rich. Radiator was taken apart, cleaned and declared to be in good shape a few months ago.
On the Canley site they mention the following:
"One very rare problem we encounter on cars that continue to overheat when all else has been checked or renewed is corrosion in the void in the water pump housing where the pump impeller usually fits. Very slight erosion here can have a drastic affect on the efficiency of the water pump. Substitution with a better S/H housing is the only answer."
Any thought or other ideas? I am not real anxious to ship a block of cast iron air-mail if it isn't going to help.
In my experience a rebuilt can be pretty tight for a couple of thousand miles causing somewhat higher temps.
