George Zeck
Just had 2 friends over and did a compression test -- all 170lbs - 180 lbs (quickly). Not Head Gasket. Heater Valve is (& was) open.
2 weeks ago; had radiator recored (outstanding job) and water pump, thermostat, hoses replaced. All up to grade stuff. Lower hose does NOT colapse when revving engine.
Drove it around and after 10 miles it so; oil pressure started dropping, valve train started clattering and engine konked out with 30 lb of pressure shortly afterwards. Letting car cool down and will bring home later.
Central part of cyl head seems much hotter than ends. Lot's of loud "boiling" noises. Have put coolant sys cleaner in radiator, yet to drain. Any Idea's ????
Tx-
Geo
Tx-
Geo
