Morris
I had a fun and busy day. I pulled the head and removed the pistons on my '79. They cylinder walls looked and felt good, but there was slop in number 2. I stuck number1 piston in number 2 cylinder and no slop. Rod bearings looked okay except for number 2 which was down to copper and pitted. The middle main bearing was down to copper, too. There was a slight ridge on the crank where the oil groove is.
So what do I do next? I am on an extremely tight budget and I do not have access to a bore gauge other than my vernier calipers. The pistons came out with ease and there is almost no perceivable ridge at the cylinder tops. I really don't want to got to the machine shop unless I absolutely have to. Whatta you guys think?
When ordering parts, is there ever a time when it is appropriate to order over size bearings pistons without a bore or regrind?
The bearings are all marked with 010 above another longer number. Do you think this means that they are .010" over?
I really want to buy flat top 9:1 pistons. Do you think I will be really asking for it if I don't go ahead and regrind the crank and bore the block?
Thanks for your advice,
Morris
Morris
