Michael J.
I have had the 87 XJ6 with 173,000 miles for just over one month now.
When I bought the car, the prior owner told me that he was having a problem with the tank change-over system.
I filled both tanks to check it out. The fuel tank selector switch was in the <font color="red"> </font> "out" <font color="black"> </font> position. The prior owner had a small plastic tube stuck in the left cap keeping the flapper valve open and keeping the fuel cap spring loaded seal from seating. He was using only the left tank and kept the right tank empty.
I bought and installed a change-over valve kit. The kit included the two non-return valves, one in each wheel well and the changeover valve in the trunk at the rear near the fuel pump.
The non-return valves have two wires color-coded white and black.
But, is it possible to cross the wires for the change-over valve? I was careful to collect the wires the same way as the valve being replaced.
I filled both tanks, presuming that the problem was solved. I drove for a few days with the tank selector switch pushed "in". When the tank was almost empty, I released the switch to the "out" position. A short time later, I had gas comming up out of the right tank, a lot of it, pushing up the spring loaded valve and overflowing down the fender onto the ground.
<font color="red"> </font> With the switch in the out position, Which tank is supposed to be the supply tank?
Any other suggestions? <font color="black"> </font>
The scematic diagram for the fuel system on page 19-2 of the Series III Service Manual appears to have some errors in which the non-return valves in the text are both referred to as the change-over valve and the change-over valve is not numbered or mentioned, although depicted on the schematic.
Should I swap the wires at the change-over valve? Is there something else to check?
