Yes, it's an old problem, but I seem to have it. I've got dual HS2s (on a 1275) and it seems that they intermittently overflow (sometimes one, sometimes both). I've taken them apart for what seems like a zillion times, but no luck. The Grose-jets are new (and seem to work well during testing) and I'd rather not jump to Viton tips for now. The floats are fine and are properly adjusted. I've also removed any crude in the bowls and the fuel is filtered. I have a nearly new SU electronic fuel pump.
Aaaargh.
So, what else might I check? Also, with an SU pump, should I consider a pressure valve so-as to better dial-in a limit? Bill (to the north of me) said that even his Joe Curto rebuilt carbs did this and he solved it with a Holly regulator. I would have presumed that an SU pump wouldn't over-pressurize. If I go that way, are there various regulators to consider?
Thanks.
Aaaargh.
Thanks.
["What we have here is a particularly bad case of Gummy Ball Syndrome. Clean 'em with this elixer and you'll be back on your feet and the road before you know it."] They sure seemed operational when I tested them but I suppose they HAVE to be the problem. Again, it's intermittent (though often), so maybe that ball is sticking on occasion.
