My OD doesn't engage when I hit the switch but I know that it does work. While taking a test drive with the transmission tunnel off I hit the switch and nothing happened. Then with the switch still on I reached over to the little lever on the passenger side of the transmission and with a little push of my fingertip, it kicked in.Do you think a new switch and silanoid will fix her up?
Hi Guest!
