Recently in an unrelated thread that I cannot find, John Morralees I think asked a question about overdrives, and as mine was not working at the time, I put my doubts about the answers aside. Now that it is, I have experimented with what the responses said, and the behaviour of mine is not what was described.
As I recall it, the post said that the overdrive switch could be left on, the overdrive would stay on but a blip of the accelerator would switch it off.
Mine works this way: you turn it on, you drop revs, you have good but less aggressive acceleration. If you want to take it off, you have to switch it off, and I use the clutch on the way down to ease the transition (anyone else think this makes sense?). If you leave it on and wind up downshifting to second or first, when you go back up, the car will shift into overdrive right away upon engaging 3rd and top.
I don't think any harm can be done by inadvertently leaving it in overdrive in the lower gears, but as I prefer to accelerate through to third and fourth in normal and shift to overdrive at my option, I do try to remember to turn it off.
Chris
Chris
Hi Guest!
