TR6 Overdrive Wiring
Gerry M
Member
I have a 74 TR6 that a previous owner installed an A type OD. The A type OD uses a relay. There is no OD relay in my car and although the existing OD wiring works it is not wired the same as the A type OD wiring diagram shows. Rather than rewire (the existing wiring works) I am looking at just incorporating a relay into the existing wiring. I have attached a drawing of what I believe to be the correct wiring for both A and J type overdrives as well as a drawing of my existing wiring. It looks like the previous owner wired my A type overdrive the same as you would a J type. My question is how do I install a relay into my existing wiring? I think this is the same as asking how would I install a relay into a J type overdrive.
TR3driver
Great Pumpkin - R.I.P
I guess the important question is, why do you want to add a relay? If you just want to reduce the load on the operating switch, that should be possible. But you can't reduce the load on the isolator switch unless you get down there and rewire it.
Gerry M
Gerry M
Member
I'm wanting to add a relay because the A type OD (which I have) originally used a relay and my understanding is that the reason for that is the A type solenoid draws much more power that the J type and therefore needs a relay.
Marvin Gruber
Ran a TR3 without relay for years with no problem and it had a generator. A type wiring is correct, no problem to put relay in as shown.
marv
Gerry M
Gerry M
Member
If I put a relay in as shown I will have to completely rewire my existing wiring. I'm hoping to connect it into my existing wiring setup somehow. Any advice on how best to do that. A diagram would be helpful. Thanks.
ckeithjordan TR2/3/3A Overdrive Wiring Triumph 5
R TR2/3/3A Overdrive wiring installation Triumph 14
S TR2/3/3A Triumph tr3 overdrive wiring Triumph 9
C TR6 TR6 Overdrive Wiring. Triumph 2
S Overdrive Wiring Check Austin Healey 12
Got_All_4 TR2/3/3A Quick Overdrive Wiring Question Triumph 6
BillyB62 TR2/3/3A Type A TR3 Overdrive Wiring Triumph 13
M Stag Wiring plugs for gear lever knob overdrive switch. Triumph 1
Gerry M TR6 Overdrive Wiring Questions Triumph 10
T TR4/4A Any tips on running the overdrive switch wiring down the steering column? Triumph 11
R TR2/3/3A TR3A Overdrive Wiring Harness Installation Triumph 19
Coyote1 Overdrive wiring question Triumph 8
hondo402000 TR6 Need Help on 71 TR6 Overdrive Wiring Triumph 9
KLUTZ Confused with my Overdrive wiring.. Help please MG 3
R BJ-7 overdrive relay wiring problem Austin Healey 1
A Overdrive wiring Triumph 8
S Overdrive Wiring Austin Healey 2
Mickey Richaud Transmission/Overdrive Wiring MG 3
S Removing Overdrive Shaft Lever Pin Austin Healey 7
nevets Reversing With Overdrive "On" Austin Healey 8
Healey Nut Overdrive Relay Austin Healey 1
T Clutch or Overdrive Slip Austin Healey 8
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
A TR4/4A TR4 Overdrive Solenoid Triumph 19
H TR4/4A A-type overdrive pump Triumph 4
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 0
Rob Glasgow New Fangled Electric Overdrive Austin Healey 9
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
J Transmission and Overdrive Rebuild Austin Healey 6
C Overdrive Failure Austin Healey 18
D TR2/3/3A Overdrive question. Triumph 49
D TR2/3/3A Type A overdrive not engaging Triumph 0
D TR2/3/3A Type A overdrive not engaging Triumph 16
BN6_2197 Overdrive engaging with time delay Austin Healey 39
P Broken Overdrive Switch in Gear Knob Austin Healey 14
T Overdrive Problems Austin Healey 18
T TR2/3/3A overdrive solenoid Triumph 3
T Spitfire Overdrive again and again... Triumph 5
BN6_2197 Replacing gearbox switch of the overdrive system Austin Healey 10
G Wanted Non Overdrive gearbox wanted Austin Healey Classifieds 0
T General Tech Spitfire overdrive, the sequel Triumph 3
T General TR Overdrive problem Triumph 4
R Gearbox and Overdrive Oil Level Austin Healey 18
C Overdrive Electrics Austin Healey 8
R gearbox and overdrive Austin Healey 1
M TR4/4A A type Overdrive Oil Leak Fix Triumph 3
M TR2/3/3A TR3 Overdrive filter drain plug Triumph 7
R Overdrive dummy mainshaft Austin Healey 1
J Overdrive Cuts Out when... Austin Healey 11
J Overdrive Cuts Out when... Austin Healey 2
