SteveHall64Healey
I have a BJ8p1 with an overdrive that no longer works following some major restoration work over the winter. I have two suspects at the moment, and wondered if anyone with a BJ8 could check the following:
1) throttle switch is closed (continuity across switch) with accelerator relaxed, but the circuit opens (no continuity) when acceletrator is pushed to floor?
2) overdrive relay (under hood on firewall, not solenoid at gearbox) - could someone please describe which wires connect to which terminals on the relay?
thanks
steve
thanks
steve
