Randall, how do you go about measuring the movement of the ball? Also, I was thinking that if the OD clutch was jammed that the pressure would not drop when the OD switch/solenoid was shut off, is that not the case?
Basically just a dial indicator, with a length of brass tubing over the tip (so it rests securely on top of the ball). You have to be careful to lift the solenoid plunger into place by hand before energizing the solenoid, don't want it banging up the indicator movement. There is more info at
https://www.buckeyetriumphs.org/technical/AOD/AOD4/AOD4.htm and
https://vintagetriumphregister.org/maintain/TransRebuild/OverDriveA02.pdf
I've not actually had a clutch stick, let alone be able to take measurements with it stuck. But I believe there will still be a small pressure drop shown as the pistons move a bit to take up the play (and flex) in the linkage to the clutch. Someone who is accustomed to working on these overdrives would likely know the difference, but it's a hard thing to describe to someone who has never done it before, especially since the amount of the drop depends both on how much wear is in the clutches and whether you have a large or small accumulator unit. Of course, I could be wrong, but if it was my car (and my back installing the gearbox), I wouldn't care to take the chance. I find it really aggravating to have to repeat a lot of work because I skipped a minor test.
PS, Enco almost always has a cheap dial indicator and magnetic base on sale for under $25. I don't use mine very often, but it is still working fine after many years of ownership. I keep the magnetic base clamped to a steel plate when not in use, which might possibly help preserve the magnet.
https://www.use-enco.com/CGI/INPDFF?PMKANO=385&PMPAGE=7&PARTPG=INLMPA&PMCTLG=01
(If that link doesn't work, go to
https://www.use-enco.com and look through the HOTDEALS section.)
I can't prove that Enco is any better than HF, but I do like them better. If nothing else, they list the better quality tools right next to the cheap junk, so you can decide which you want. If you would rather have Starrett quality, they also have those at a reasonable price (for the best available).
