OK - here's my TR6 O/D 'war story'. About 10 years ago a guy sold me a g/box and A-type OD pulled from a scrap car for $750. Had to replace the side cover that the solenoid mounts to - it's vulnerable to breakage when it's off the car. Not too much of a problem since it was available from VB. Also had to buy the speedo angle drive, longer speedo cable (I think), the electrical harness, and switch. The disappointment was that the gearbox was done for - one of the gears up front was was mostly ground away (I think it was the gear on the layshaft that engages with the gear on the input shaft). The gearbox I was taking out was already noisy, and I wasn't going to attempt stripping it down, trying to switch the output shafts, etc. So I used the dead gearbox as the exchange one for a rebuilt one from Rimmers in UK. As I recall the shipping to the US was very low (free special even??) - sending the exchange back was $$ though. I went through and changed some parts in the overdrive- the accumulator o-rings seem to stick in my mind. 10 years and probably 30k later I have been happy with it. It does leak, I should have changed the tail shaft seal, and I think it is oozing at the joints between g/b and o/d. As far as being hard to get into second, the old one and new one have been the same way- only an issue for about the first 5 minutes in the cold. As far as all up $$ - I think all together it was around $2000- more than I had planned on, but I do think it adds a lot to the car. People are looking for it when they're TR6 shopping, for sure. Good luck with the new one.. - Pete
