'77 MGB w/ LH Overdrive...a little while back, I did a complete lube on my B (motor, trans and rear axle fluids changed out). While servicing the trans, I removed what I "thought" to be the drain plug in the OD. Only...surprise...there is no drain plug. What I removed was the plug that holds the low pressure relief valve. I found it later in my drain pan when I was emptying it.
I put it back in with the narrow side up and the little round filter screen at the bottom (it wouldn't go in the other way). Today, I have my B out for a drive and I switch to OD and...nothing. Nothing at all happens. I believe it to be the valve; I probably installed it incorrectly.
Long story short, can anyone offer any suggestions or advice? I should add that the gearbox oil level is correct, Castrol 20w50, and I did clean the OD filter/magnet set.
