M
Member 10617
Well... here I go. Tomorow I'm going to change the gearbox/OD oil in my 58 TR3. I've changed the engine oil several times since getting this car, but this will be the first time for the gearbox/OD.
I have an "Overdrive Drain Plug Spanner from Original Duplicates," so I think I'm equipped. But the tool came with the following statement: "It is often very difficult to remove since it seizes in the aluminum case. This tool is designed to engage one of the (6) notches and provides proper leverage for safe removal and replacement."
I can't tell if this is a WARNING (the plug is difficult to remove) or REASSURANCE (this tool can do the job).
Before I dive into this -- or rather dive UNDER the car to do this -- can anyone give me some pointers or tips from experience on how to go about removing the plug.
I do know that I need to replace the fiber gasket (which I have) and apply antiseize compound to the threads. But first, I have to get the thing off without stripping or breaking anything. (Intereesting how "delicate" these robust cars can be.
Sounds to me like one of those situations that Dr. John is very familiar with: brass seizing in aluminum casing.
