Overcooling Healey 100
BobAH100
I have a most unusual Austin-Healey: It NEVER overheats, even at highway speeds on a hot summer day, thanks at least in part to an alloy Wizard radiator, performance water pump, and D. Welch alloy head. Engine was gone through and rebuilt from the new steel crankcase and con rods on up. Yet, despite trying both the 160 and 180-degree F thermostats available from Moss and others (modern disc type), it runs too cool on a cool morning, even at 50 to 60 degrees F.
Aside from covering part of the grille (which a photo of Donald Healey in the prototype Healey 100 at Jabbeke shows was done back then!), might the original type sleeved/bellows thermostat work better? Thanks in advance for your thoughts!
GregW
Platinum
Are you sure your measuring equipment is accurate?
B
BobAH100
Will consider that. I’m just wondering whether it’s the design—modern disc vs sleeved bellows thermostat as original—that’s the issue.
John Turney
The heads have a bypass passage that recirculates coolant to warm up the engine faster. When the older thermostat with the sleeve would "open", the sleeve would block the bypass passage so almost all the coolant would go through the radiator. With a modern disc, coolant will continue to flow through the bypass passage and not go through the radiator. In summary, the old style is supposed to result in more cooling.
These cars usually tend to overheat when stopped or in stop-and-go traffic, not at highway speeds. When it's 75F outside, what does your temperature gauge read? On mine, once ambient reaches ~70F, the temp gauge reads about 100F above ambient.
B
BobAH100
Same here. As I said, cooling isn’t the issue. Since all the thermostats Moss and others sell are made in China, I will try a thermostat made in Germany from the 1970s—new old stock—to see if it lets the car run warmer in colder temps and heat up faster, which is what any good thermostat should do, without causing the engine to overheat in hot weather. Will report my results. Stay tuned ...
CraigC
Bob, you never did say what the temp was that you were seeing. Also, was the performance water pump sourced from the individual who rebuilds them on the east coast?
The heads have a bypass passage that recirculates coolant to warm up the engine faster. .....
John, this feature is specific to the 100-6 and 3000.
The bypass passage in a 100 is from the side of the water pump, directly beside the impeller, into the coolant galley that runs down the right side of the block. It is approx 1/4" x 3/4" and is always open.
B
BobAH100
Thanks guys! My Hundred runs between 70 and 80 c on the hottest days, which is great. But on a cool morning, where it’s perhaps 50 to 60 f outside, the gauge reads 50 to 60c (yes it’s a ‘53 so the gauge is centigrade). And the water pump is Denis Welch as is the alloy head, while the alloy radiator is Wizard. I’m about to try a different thermostat sourced from Germany (new old stock). Worst comes to worst, I’ll cover part of the grille as D Healey did on the prototype!
vette
BobAH100,
My BJ7 has a centigrade water temp guage. (presumably because it was originally delivered to Germany). My temp runs at between 70 & 80* centigrade during most driving here in the northeast. That’s around 175 - 180* F. On really hot days meaning 90s and high humidity it will creep into the 90*c range in slow traffic. On really cool mornings the temp gauge will struggle to get above 70*c. My engine is a stock 3000 with a stock but cleaned out radiator. I’m running a Texas Cooler fan.
I suspect your wee bit cooler situation is do to the aluminium components installed.
Just to be my usual contrarian self: Just because something is made in Germany doesn't automatically mean it's super quality. My '96 Ford Ranger has the 4L 'Cologne' engine--and thermostat--made in Germany, and the temp gauge would barely get off the peg from the time I bought it new (custom-ordered fleet sale). I finally got around to swapping in a Stant--AFAIK made in the USA--and the temp would get to mid-range on the gauge and stay there. Heard/read somewhere that all of those engines suffered that problem; i.e. a stuck-open thermostat. I still wonder if any damage occurred from running too cool for several years.
John Turney
Thanks Craig. Always learning something here.
B
BobAH100
Thanks for all the suggestions! I have a vintage USA made thermostat as well and may try that as it’s rated at roughly 180f.
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
S Healey Will Not Start (a.k.a. "Failure to proceed") Austin Healey 3
dougie Jack & Bill Rawles attending The Healey World Challenge Road America September 13-15 Austin Healey 2
Editor_Reid New Edition of "Austin-Healey Quarterly" Available Austin Healey 1
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
dougie Healey Hardtop on BAT Austin Healey 8
dougie Austin Healey 4000 Austin Healey 3
Patrick67BJ8 Healey Mechanic Needed - El Paso, Texas Area Austin Healey 0
T Healey In An Ice Cube Austin Healey 6
dougie VSCDA Healey World Challenge Road America Austin Healey 0
dougie Healey World Challenge 2024 Road America Racing 0
R Healey 100 Dipstick Stuck Austin Healey 12
L For Sale Austin Healey Parts!!! Austin Healey Classifieds 0
tahoe healey Healey Video Austin Healey 0
W Nash Healey Austin Healey 5
S Wanted WTB: 3.5 ratio diff/pumkin for '67 BJ8 Healey 3000 Austin Healey Classifieds 0
dougie Celebration of Austin Healey Double Event September 2024 Austin Healey 2
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
nevets Letting the Healey go... Austin Healey 4
dougie Healey Racing Road America Fall 2024 Austin Healey 1
R Big Healey 100 Head Austin Healey 4
PAUL161 Photo: What Model of Healey? Austin Healey 7
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
Guido36 Webers on a Healey 100 Austin Healey 6
E For Sale Driver quality 1963 Healey 3000 mark 2 Austin Healey Classifieds 1
Editor_Reid Summer Edition of "Austin-Healey Quarterly" Austin Healey 4
dougie Healey Racing Austin Healey 13
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
red57 Alternative Healey Austin Healey 2
Dandare Healey Website Links Austin Healey 4
John Turney An Important Healey Up For Sale Austin Healey 1
M For Sale Austin Healey 100-4 Lemans Kit OEM Austin Healey Classifieds 5
V Opinions on 1953 Austin-Healey Austin Healey 26
dougie Did Big Healey Drivers Go Soft? Austin Healey 8
C What to do with my late father's Healey 100 Austin Healey 5
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
B Healey Won't Start - No Spark Austin Healey 38
Editor_Reid "Austin-Healey Quarterly" e-zine Spridgets 2
Editor_Reid "Austin-Healey Quarterly" e-zine Austin Healey 8
BoyRacer Silver Healey - Chassis Color? Austin Healey 17
HealeyRick Perfect Healey Floor Jack Austin Healey 14
T Netflix Christmas Film with a Healey Austin Healey 4
W For Sale 1954 Nash-Healey Le Mans Coupe Other British Classifieds 2
N For Sale Austin Healey Frogeye Sprite Spridgets Classified 0
dougie 1960 Austin Healey 3000 Works Lightweight vs. 1962 Ferrari GTO Austin Healey 6
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
roscoe An Unusual Healey Mission Austin Healey 2
D Healey 3000 BT7 rear panels Austin Healey 0
Rob Glasgow Why I bought my Healey Austin Healey 6
