Time for action. I'm pulling my radiator--now.
Today I ran fine until I idled outside my garage after a long drive, and in just a minute or two I actually went into the red zone, even with my auxiliary fan on. That seems extreme, even despite it being about 108 degrees today.
I've got a rebuilt engine, a very clean water jacket in the block, and a 5 vane water pump, for what that adds.
I'll report what I learn, in case it's of value, but in the interim let me ask a few questions for educational purposes:
a) When I stop the car and the water spills over in the overflow bottle, what is actually happening? Is the radiator cap allowing bypass, or is the coolant just boiling on down the plastic overflow tube and over-filling the bottle?
b) The housing of my water pump appears to have a slight white residue on it, as if coolant may have leaked there, but I can't see that any leak actually exists. Any thoughts?
c) What would be the symptoms of a bad radiator cap? When I lifted the pressure release today, after the engine had cooled for about 5 minutes, there wasn't much of a release. When I took the cap completely off, however, a little more air or pressure was released.
d) Since I run at proper temperature on the long straight-aways, does any of this sound like a bad thermostat? I'm running a 160 degree thermostat.
thx
thx
