Outer Wheel Bearing - interference fit v Quality?
MrAlex
I am rebuilding the front suspension on my TR4 (and I'm ... almost... done!). Upon dissassembly on the starboard side I observed the outer wheel bearing inner race had spun on the stub axle. I obtained a Stub Axle (5-4019) and outer wheel Bearing (5-731) from Victoria British. (I was ordering another part as well so went with this supplier for these parts). I had the old Stub removed from the vertical link and installed the new Stub. I reassembled the suspension. Upon installing and packing the new outer wheel bearing I had a problem getting the outer bearing to go on the Stub axle.. Hmmm. I mic'd the Stub and it looks close to 15.9mm. I measured the inner diameter of the wheel bearing to be 15.8mm. The old inner race measures 15.8mm also. The Port side stub looks to be 15.8mm but that might be worn? I've done a few wheel bearings in my life but I never remember an interference fit??? I'll be making some phone calls to suppliers tomorrow to inquire about this but I figured a post might help. Perhaps another supplier quality issue? Has anyone had a similar problem like this or do I have a bad part? I do not want to force this on without further reasearch. Any insight would help.. Thanks
Re: Outer Wheel Bearing - interference fit??
The inner wheel bearing races are <u>not</u> an interference fit onto the stub axle, they are a slide fit. Looks like your new stub axle is too large in od, another supplier quality issue..... I would call the supplier and return the defective item. Next try that company in the wilds of Penn. I'm sure they will have the correct one /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
What he said !
