red57
I am plodding away at this restoration project and last weekend started to fit the outer sill on the right side. I have already replaced the inner sills and was ready to fit the outer sills when I found a potential problem. On these replacement sills, the surface that will be seen after assembly is about 1/2 inch longer than the door skin that sits above it. I bought these 2 years ago along with most of the sheet metal I knew I would need, these came from Moss. I am not interested in bashing a supplier, only mention the name here in case other suppliers have different sills to offer. Has anyone had good luck with outer sills that fit well? My doors measure about 31 1/2" along the bottom & these sills would work well with a 32" long door. Does anyone have any suggestions before I start trying to move the depressed area to line up with the wings? The attached pictures are with the door, front wing, and dog leg repair piece just laying on the floor to show the issue. Any thought will be welcome.
Dave
Dave
