Only Varibles should be Referenced
it is not a problem
It is just a screen that pops up occasionally when we edit a post
Does this happen every time you make a reply (or edit) using Advanced Editor, or just some times?
Yes it happens every time I select "Go Advanced" to open the advanced editor to reply to or edit a posting. It does NOT happen when I use the "Quick Reply" to do the same thing.
"HEBREWS" okay you solved my problem! Thank you.
