One Step Backwards.......
AngliaGT
I decided that I'd finally get around to installing the heater box.
Open hood
Notice a hose in way
Take hose off
Notice that there's a metal line in the way
Take clamps off of metal line
Battery's in the way - remove battery
Noticed that there's a space for the metal line
to go through on the heater box
Put heater box into position - can't get bolts started
Remove heater box - still can't get bolts started
Reinstall battery,line clamps,& hose
Put Midget back in garage
Go back in house - tempted to take up drinking again
Sounds like my last month in the garage. Progress comes slowly sometimes....
And to add injury to insult,the plastic choke knob broke,
cutting my finger.
I went to bolt in the Fuel Pump on Bugsy to the rivnut I had previously installed on right rear panel. I tried using a NF bolt instead of a NC thread bolt. When it didn’t go I ran a NF Tap in there. Now it mean replacing the rivnut. I hate when I I screw up at end of day when I’m tired and try todo one more little project.
But I had a triumph with bolts I screwed up and fixed them but now 2-3 hours on that project. This crap takes forever.
Doug, you probably already know those threads are 1/4 x 28. You probably will have to clean up the threads. I had to run a tap through mine but if you have or can borrow a thread chaser it is less dangerous.
Spent all afternoon the other day getting brake line to rear of car fit. Went to install starter and SOB no matter how I clocked it I could not get starter to go in without ripping out the brake line. Time to get some cupro nickel and splice into part of the line. I hate brake lines����
