After seeing a post on the MG forum about vented oil caps I checked the Midget cap closely and found it to be vented. When new valve cover goes on so does a new cap. Hopefully no major damage.
I'm wondering which engines would have used a vented oil cap on the rocker cover? I'm trying to get my '63 1098cg set up decently, oil leaks abound and it seems like the drip tube really works......Have after market aluminum cover with hose to Weber air filter, current cap doesn't appear to be vented.
I checked the original cap on the stock rocker cover. (PO had installed polished aluminum). OEM cap is vented but is not interchangeable with fancy schmancy alumunium cover. So, in the ongoing struggle to reduce oil drippings, I'm going to try a vented cap but it seems I can't just buy one from Moss or VB, at least neither list one for the after market covers as being vented. Are these at all universal?
BTW
Anyone care to explain how a vented cap would change things? If the tube from the rocker to the air cleaner is supposed to pull a vacuum wouldn't a vented cap defeat that?
