General Tech One Person Brake Bleeding with a Mityvac
Richter12x2
I changed out my rubber brake lines for new braided stainless ones on the Triumph GT6 yesterday, so today it was time to bleed them.
I spent about 30 minutes by the passenger rear wheel, pumping the mightyvac like crazy to keep suction in it, and getting nothing but a long stream of bubbles that never improved. I finally gave up and moved over to the other rear wheel, with the same results. This is pretty much what happened last time, where it finally ended up good enough to get it to a shop and pay someone about $100 to bleed the brakes with a pressure bleeder. Wasn't looking forward to that again, but I knew I at least had to finish the 4 wheels to get some sort of brake fluid back in there before I could even consider getting it down and over to the garage.
Forearms hurting from pumping, I took a break, and pulled up Google on my phone and searched "How to bleed brakes with a mightyvac" and got this video: https://www.youtube.com/watch?v=KTY2iBkFeV0
So I'm watching, and he gets to the part about taking the bleeder valve out and putting 4 loops of teflon tape on it and putting it back in, and I'm thinking "Okay, that's probably overengineering, it can't make that much difference, you're just going to be wasting brake fluid while you put the teflon tape on". So I went back to the passenger front wheel, pumped up the mightyvac and cracked the bleed nipple, and same story, bubbles like crazy and no signs of improvement. So I thought "Well, heck, I'll try it, and if the guys at the brake shop laugh that I have teflon tape on my brake nipples, so be it." Stuck a cup under the caliper and pulled the nipple out, wrapped it around 4 times with teflon tape, and threaded it back in. Topped up the master cylinder again, hooked the mightyvac back up and pumped it up to 20 again. Cracked the nipple and a solid wall of clean fluid came through, with just a few microscopic bubbles (which he explained are usually just from sucking air up the threads.)
More telling, now, from the initial pump up to -20, it only got to -15 before I had to top up the master cylinder. Before I would pump to -20, crack the nipple open and run it down to -5 about 7 times before I had to top up. (I counted, because I'm doing this in the garage and it's a pain to get out from between the wall and the car to check the fluid level, but I didn't want to run it dry either.)
After another 2 top ups, I was satisfied I had a totally negligible amount of air in the lines. This is probably the 10th time I've bled brakes on a car and the first time I can really, honestly say that I feel good that I'm sure I got it all, and it took about 5 minutes to do the corner, vs 30 minutes of flailing to no effect.
Re-did the other wheels, with the same result, every time. I went ahead and ran through the rest of the brake fluid on the rear wheels since it goes bad storing it, just to be sure that I got it all, but it was pretty obviously perfectly fine long before I wrapped up.
A quarter's worth of teflon tape, and a minute to pull the nipple and wrap it, to save $100, (or a life, potentially, from dodgy brakes). I'm definitely a believer now.
HerronScott
I've always used the MityWife method of bleeding brakes ("pump.. pump.. pump and hold...") :smile:
Scott
dklawson
I have only vacuum bled once or twice. I don't have a real Mityvac, I have two generics. Both the generic tools mention using sealant on the bleed nipple threads. It does make a difference.
I have never used the pump, pump, pump and hold method to bleed brakes. I use a modified version of the 2-person flush method. I have a bleed hose with a check valve in it. I put grease (yes, grease) on the bleed nipple threads (instead of Teflon tape), connect my bleed hose, and crack the nipple one-half turn open. Then I top up the reservoir and SLOWLY push the brake pedal down while watching the bleed hose. I repeat the slow pedal depressions until I see no more bubbles coming out of the hose. The check valve and grease on the nipple threads allow me to do this work without the assistance of a helper. My "helpers" always seemed to get annoyed that I was using so much of their time.
An alternative to my custom bleed hose, the grease, or Teflon tape is to buy the correct size of Speed-Bleeders. Speed-Bleeders have built in check valves and a sealant on the threads.
R
Richter12x2
Scott
I've tried this method a couple of times, it works alright but it seems to cause some hard to eliminate whining and groaning that lasts long after the process is complete. :D
Bob Claffie
I had a similar experience bleeding my MGB. Exiting fluid looked like foam with the vacuum gizmo. Obviously air sneaking past the bleeder threads. I finished it off with the "pump,pump,hold" system and all was fine. As a side note the vendor of the "speedy-bleeders" also sells a thread sealant as the speedy-bleeders are only good for a few uses before they start to inhale air through the threads.
tdskip
I've found that using the brake pedal to get fluid going into a container and then using a Mityvac to finish the job is a lot more time effective knowing first hand what the OP describes.
R
Richter12x2
The nice thing was, it's actually kindof a combo method, because when you take the bleed nipple out to put the tape on, you're actually letting the brake fluid drain air out of the system as well, truth be told, by the time I hooked up the mighty-vac, most of the air was already out of the system just from using the 'gravity method' that I've heard some people swear by. I had clean solid wall of fluid on the first pump on all 4 corners. I gave a couple of pumps of the brake pedal before I started just because I ran the master cylinder dry accidentally while trying to get the brake lines on (one of the existing lines had some sketchy threads on it, so it took too long to straighten out, even with plastic wrap stuffed under the master cylinder cap.)
RJS
I've always had luck with a one way check valve (Ezee Bleed I think its called). Stock bleeder screws but I honestly can't recall if I have teflon tape on the threads of the bleed valve. I seem to think I do.
HerronScott
So that's what was causing that? ;)
Scott
sail
Another vote for speed bleeders. Never had much problem the conventional way but speed bleeders for $30 or so well worth it. One man job and no gizmo needed.
T TR2/3/3A One Person TR3 Brake Bleeding Option? Triumph 11
JPSmit troubleshooting signals - if you were a betting person. Spridgets 21
Northcoaster TR4/4A Lost info on person interested in my valve cover Triumph 1
Rut TR4/4A Nice project for the right person Triumph 0
Sarastro TR4/4A I am now a Triumph person Triumph 7
B MGB-GT Best rust repair person/shop on the East Coast? MG 2
Ed Kaler Non-Healey but Healey person Austin Healey 3
B MGB-GT Place or Person to Paint my GT in Dallas/Ft. Worth MG 6
jlaird Some nice person, I wonder who Spridgets 0
B MGA Axle Brake line MG 0
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
71TR6 TR2/3/3A Aftermarket brake and clutch master cylinders - black extension? Triumph 6
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
E TR4/4A What Flare to put on a TR4 Brake Line Triumph 2
T Spin-On Oil Filters for Cars with a Brake Servo Austin Healey 3
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
B Rear Brake Cylinders Austin Healey 4
K TR2/3/3A Brand new brake caliper question... Triumph 8
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
Chrisc9 TR6 TR6 brake light Triumph 6
L T-Series Another brake prob. ? MG 12
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Sopwith_Camel MGB pulsing brake pedal MG 10
Got_All_4 TR6 Triumph TR6 PDWA Brake Question Triumph 1
bighealeysource Front Brake Adjusters Austin Healey 0
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
TAS525 TR2/3/3A Thoughts on Brake Pads Triumph 12
Gundog61 BN2 Brake Drums Austin Healey 5
KVH General TR Rear Brake Shoe Orientation Triumph 12
R TR6 Help: Brake Part Source or …. ? Triumph 1
mezy vauxhll brake pipes Other British Cars 0
KVH General Tech TR4A Brake Bleeding Triumph 5
R Brake Adjustment Spridgets 2
Walter74 Brake Servo Location Austin Healey 6
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
KVH General Tech Brake Fluid Triumph 5
