M
Member 10617
As I prepare to remove my differential for a rebuild, I have gotten much good guidance from the forum. Thanks to all. Sorry that my questins are pretty basic, if not to say "dumb," but I am learning.
One last question.
All say, and everything I've read says, that before removing the differential, I should aim the rotor to the number 1 cylinder for timimg purposes.
The firing sequence on my car has been modified so that the lead that normally connects to the #1 cylinder, now connects to the #3 cylinder, and the lead that normally goes to the #2 cylinder, now goes to the #1 cylinder. This seemed strange to me, bur the mechanic explained that it was done that way to give the vacuum advance a little more room. Anyway, the firing sequence is still 1-3-4-2.
My question is: when I remove the differential, should the rotor point to the number 1 cylinder (which would mean it is pointing to the #3 lead on the distributor cap) or to the present location of the #1 lead (where it is presently located on the distributor cap), which would mean it would be pointing at the #2 cylinder?
One last question.
