I haven't done it yet but I stopped at HF a few minutes ago, they had the advance timing gun I want (I broke mine and it wasn't the advance type) but they didn't have the leak down tester. What did you end up paying? I think the process is pretty similar to compression test I believe, pull all plugs, set a cylinder to TDC (so valves are closed), car in neutral (so it doesn't turn over on you I guess) put in 100psi and see how far it drops and holds, if you hear a hiss from the exhaust you have a leaky exhaust valve, if you hear a hiss from the intake side, bad intake valve, if you hear something in the crankcase venting somewhere: rings.
