Well after my last coil episode, I put on an old style 40Kcoil with metal wires and those plastic end pieces. Now a new problem occurred, the engine popped upon starting while out on test run and then started to miss. Well I changed out the coil, condenser, points, plugs, checked the floats all while on the road and nothing fixed it. Anyways, drove it home missing badly and changed the cap and that fixed it. Turned out the little plastic end pieces shorted or something. I cannot even get a resistance/ohm reading on them. I checked some other ones I had and they measure 7K. So what happened? Could the old coil of toasted them?
I remember buying un-made metal wirer kits as a kid and they just went straight on. Are those kits you mention Geo unmade up? Plus it sounds like if I want solid wirer I need to purchase it online. The metal wirer I have is the bumble bee stuff from Moss and I believe it will need the plastic ends also and if that is the case it might be best to stick to the carbon.
