Tabcon
I'm not going to go into the personal and exceedingly boring details about the divorce I'm going through, so it's okay to read on. By the way, the question posed in the above subject line is rhetorical.
I actually DO know who did this sophomoric prank, but that's not the point.
The point is someone, anyone poured what looks like about a 1/2 to 3/4 cup of latex house paint, along with various nuts, bolts and washers into my oil filler cap a couple of weeks ago before I regained exclusive use of our home, and more importantly my garage.
Fortunately, fate had been shining on me that day as I had decided to pull the valve cover to tighten the emblem on the top of it. It was at that time that I noticed both of the no. 4 intake and exhaust roller rockers were a lovely shade of dark gray green, while the remainder of the rocker arms were the standard shade of gold aluminum.
If anyone can offer any suggestions other than what I've already done, please do, as this is the very first time someone has poured paint instead of oil into my filler cap.
Obviously, the rocker arms and valve springs were coated, as well as the two push rods, but not so much as I would have expected. I removed the entire rocker arm assembly and throughly cleaned everything, re-oiled it and reassembled it.
Next, I removed the head, and all the tappets. The two no. 4 tappets were almost filled with green paint, but amazingly enough, very, very little seeped past them to the cam. There were a few tiny spots paint on the cam, but they were easily removed. I spun the engine over slowly by hand and found no additional paint on the camshaft. The 2 no. 4 push rods were also cleaned and I also removed the paint that collected on the top of the head below the valve springs. No paint at all made it past the valve seals, but the springs were pretty well coated so I used my compressor and some WD-40 and some teeny tiny picks to remove every little bit of paint between the springs and the seals. I also plan on draining the crankcase and flushing it with some fresh oil before refilling it.
I doubt that the paint would have done any serious damage since it would have broken down and I would have been changing the oil in a short period of time anyway. The bolts, screws, washers, and tiny nuts I found lodged between the rocker arms and valve springs is a horse of a different color and could have caused a little grief for sure.
On a positive note, it was actually enjoyable to take it all apart again, inspect it, re-lube everything and now put it back together. I've missed working on it and this was as good a place to start as any I suppose.
