well, I thought I had a solution for my brake pressure switch issue. went to check and ..... nothing
battery is good, I suspect solenoid since I just replaced it but, could be a starter wire issue also.
so, to isolate before I pull things apart, can I test the starter by running a jumper straight from the battery and touching the big bolt on the starter?
If so, do I run the cable from the positive or negative on battery? and do I keep the battery grounded?
