Hi all,
I agree there are a lot of factors that go into a well-tuned exhaust header/exhaust system.
However...
Isn't it fair to say that most people won't be designing, bending and welding up a set of carefully tuned headers for their street car? I'd expect most will simply shop among what's available and buy a ready-made set from one or the other of the major vendors. And, besides, just how precisely can we expect a street car's exhaust tuning to be, or is even worthwhile in terms of expense/effort in relation to real performance gains?
Sure, a few really talented individuals may want to go through a design exercise, make up their own header and experiment with the various tuning characteristics. But, I'm guessing that the rest of us will be buying from among what's available off-the-shelf.
There's a limited selection of ready-made headers out there, both for the 4-cyl. and for the 6 cyl. TRs. But, there is some real possibility of buying a header that's less than suitable for street use. I've done it myself and seen an awful lot of 4 cyl. cars, in particular, using the "wrong" type header simply because these are what's been most common and are often cheapest.
Below are three pictures of header types for 4-cyl. TRs. (Photos are borrowed from
www.cambridgepotorsport.com's online catalog, the only webisite I could find with good illustrations of the various header types). You'll find similar variations in header design for the 6-cyl. engine.
In general terms, when buying TR headers off-the-shelf we don't get much choice of primary tube diameter, so that leaves primary length to consider (plus construction, finish and materials: see below).
Short primary:
This type are similar to what was fitted to the 12-Hour Sebring TRs (a Kastner design) and might be expected to give the best street performance, i.e., reasonable flexibility for low- to mid-rpm work (and peak HP at approx. 5000 rpm). In fact, among the choices, this design is closest to the original cast manifolds in it's dimensions.
Long primary:
These headers are more for pure road race, appear to be based upon SAH/Kastner designs for for high rpm work with improved production class motors (peak HP at approx. 6000-6200 rpm). At one point this was about the only type available, and there are alot of them around, from several different manufacturers.
Really long primary (less common):
These really long primary headers are most intended for ultra high performance with more highly modified motors (peaking up and over 7000 rpm).
In this and previous posts I've expressed concern that the second type - the long primary - is what's very often sold to TR owners for installation on their street cars. It's the only design some vendors offer. Installing a set won't ruin a car, by any means, but I think a better off-the-shelf solution for most street cars is the first type: the shorter primary design. Those are becoming more widely available and should provide better manners in most street driving situations.
Another major consideration when shopping is header materials. The choices are essentially two: mild steel or stainless steel. Mild steel is cheaper, easier to work with and might be just fine for a long time in a car that's driven frequently (this helps keep the exhaust system clear and dry). Stainless is more expensive, but can last indefinitely, might be the best choice for infrequently driven cars. By the way, stainless are usually the preferred chioce when wrapping a header to help reduce heat under the hood, while mild steel might be the choice if ceramic coatings will be used. Both wrapping and ceramic coating can improve gas flow, too.
Whatever design, finish and materials are used, the actual construction of the header is also important. It should have solid welds of course, but also nice, smooth mandrel bends (no "crushing" on the inside of the bend), roughly equal length primary tubes and nice, thick mounting flanges. Nearly all headers require some fine tuning for best fit and seal, too. /ubbthreads/images/graemlins/hammer.gif
Finally, yes, what comes before and after the header are also important. A good header might be mandatory with certain other modifications (i.e., Weber sidedraft carbs), and is usually part of any overall engine improvement plan. A freer flowing exhaust will make most effective use of a header, but that's a whole 'nother topic!
