I am willing to detail something that I did that was really dumb, maybe you'd like to reminisce about a mistake that you made that may have bitten you hard or that you managed to skate on by a cat's whisker. The older I get the less I care about revealing these things so here is mine.
This past weekend I took the Healey out for an overdue spin to the grocery store as a warm up for a cruise up the Capay Valley for our annual almond blossom festival. In the barn, the battery was a bit low and after some cranking I had to jump it. With a the alternator I put in last Fall I figured it would charge up going to town. En-routeI was disappointed to see some large fluctuations in voltage accompanied by a very intermittent misfire. On top of that I had to jump start it at the store again (love those jumper pacs). At home again. Starting with simple stuff I uncovered the batteries, which for me are 2, 12 V batteries in parallel. Because of the paralleling wiring there are more battery cables than were original. I did indeed find that the batteries were embarrassingly low on electrolyte and that the battery terminals were also corroded enough so that between the two I was pretty sure it would be a simple fix. So you probably already know what I did and you are correct. Suffering with a cold and having my nose running every time I bent over behind the seats to work, I managed to push one cable out of sight and misinterpreted the "set" that another cable had taken and as hard as it is for me to accept, I wired them back up in series. Big fat grin on my face for actually finding a problem I hoped would be the fix, I turned on the ignition and in horror saw 23.5V on my volt meter. It was so surprising I hesitated for about 5 seconds before I decided that the voltmeter would not lie about this. I was sure I had fried lots of wiring and instantly knew what a nightmare it could be. I was just waiting for the smell of burnt insulation. But then....nothing. No harm, no foul. All I can figure is that since I didn't have a current draw on anything but the coil for that time there was no current flow anywhere else. Had this been a modern car it probably would have been a total loss for frying the electronics. Lucky doesn't describe it.
I've got more, like the time I found a bad end on an extension cord and proceeded to do other things for a while, returned to it with parts to fix and grabbed my dykes and cut the end off while it was still plugged into the wall 20 feet away. Maybe there is a theme here. Anybody care to join in with a Healey related screw-up?
Hi Guest!
