Further to my post of a few days ago about low oil pressure I pulled the bottom end apart and will be replacing rod and main bearings. I removed the oil release valve cap nut and spring but cannot get the valve itself--the plunger--out. I had a small magnet probe that seemed to go all the way into the plunger's recess but it would not extract the part.
Is there some trick here? I had it out a number of years ago and do not remember encountering any problem. I could probably pass a tap into it from the side and engage the inside of the plunger so I could extract it but there must be some better way. Suggestions/experience appreciated.
