My new Woodruff Key for the oil pump shaft fits too loosely, and if I'm not careful it falls out, almost into the cam gear area or down to the oil pan. I realize it won't go anywhere once I'm done timing the car and installing the distributor, but it bothers me that there's so much play. My older key fits better but appears dinged up a bit. In fact, I had a heck of a time adjusting it for reuse if I go that route. I fine sanded out a small burr, and I can reuse it.
Is this another example of "why did I get a new one," or have others had experience relevant here? Is the "play" something I can ignore?
PS It's not the shaft. I have a new one to compare, and it doesn't solve the Woodruff Key issue.
Hi Guest!
