Oil Pump spin up Question
DNK
On a 6, when you spin the oil pump by drill, should oil seep out of all the rocker holes?
Platinum
I'd expect to see ~some~ oil up there but likely not a lot. Do you have a "hard" gauge you can view as you spin the pump? That'd tell you more than visually "measuring", methinks.
DNK
DNK
It's for a friend. Says he has beem spinning the heck out of it and only getting oil from 6 of the 12.
I think this is about right.
Think he wants to make sure everything is correct up top
Doc with a drill how much oil pressure could you expect?
Platinum
Too many variables, really. But, considering the pump/cam gearing to be close to 1:1 and engine idle speeds in the 1K RPM area, if you can 500+ RPM from the drill you should see something near "normal" for pressure at idle... 35~40 PSI, mebbe. With 1K~1500 drill speeds the thing would read 60-ish, up to pressure relief valve pop-off. Somewhere "north" of 75 to 80, IIRC.
M_Pied_Lourd
Yep, make sure the drill is in reverse. Don, I was able to see 60 on mine.
Cheers,
Tush
TR3driver
Great Pumpkin - R.I.P
I suspect it may depend. At least on the TRactor motor, the head is not fed from the oil galleries but from a hole off to the side of the rear cam bearing. The cam journal has a flat on it that acts kind of like a metering pump to allow only a small amount of oil to flow to the head with each cam revolution. With the cam not turning, you might not get much flow to the head, regardless of the main oil gallery pressure. And since the rocker shaft is tilted, it takes a certain minimum flow to fill it and force oil out all the weep holes.
Not sure if the 6 works the same way, but it seems likely.
DNK
DNK
My friend rotated the motor a little bit at a time and tried in each position
EDIT
His remarks
♠spun the pump up for many minutes. Rocker # 3; counting from the front of the engine, positions # 5&6 immediately started seeping oil. After some minutes, position #3 and then # 1 came on line and some minutes later position # 8 followed a good while later with position # 7. For reference positions 1&2 are cylinder # 1, then 3&4-cylinder # 2 etc. Rocker # 2, 9,10, 11 and 12 have yet to produce oil through the little hole, but oil came out around the rocker on #9, but 11 & 12 show no evidence of any oil anywhere. I spun the sucker for 20 minutes or longer and rotated the crank every 4-5 minutes through 22 degrees or so until I had a complete rotation of the rockers through a complete combustion cycle. Still no oil on 11 and 12.
TR3driver
Well, what are the other circumstances? Might be worth pulling the shaft apart, to be sure all is well inside. They do get clogged with sludge sometimes.
But I would probably start it first and see what happens. Unless the rockers are totally dry, running for a few minutes isn't going to hurt anything.
DNK
DNK
Brand new motor and shaft so hopefully no sludge in it
EDIT
Who was it that just had a shaft go bad. Wasn't it a fairly new shaft?
TR3driver
I forget who that was offhand, but the post-mortem was that the shaft had been made wrong.
Brosky
If you're worried about it, then it's worth pulling off and checking completely before starting the engine, IMHO.....
ACTUALLY...if you do pull it and spin the oil pump you will see how much actual oil is coming out of the small galley hole at the back of the head that feeds the rockers.
EDIT: as in this little guy shown here:
Platinum
That'd be a 'next step' in my opinion. FWIW. :wink:
TR3driver
Thing is, he knows he's getting some oil out the port in the head, because there is at least some oil coming out of most of the rockers. And unless he's parked on a hill, the dry rockers are also the lowest rockers (11 & 12).
So it seems to me the problem must be oil not getting from the center hole in the shaft, to rockers 11 & 12; rather than any problem with oil getting to the pedestal.
At any rate, that's where I would look next.
DNK
DNK
It's been a while. How many ped holes are there?
poolboy
Yeah. And as Randall explained, it's pumped up there by the cam, not the oil pump per se, so the oil is not under a lot of pressure in the valve train.
KVH TR4/4A Using Drill to Spin Oil Pump Shaft Triumph 10
KVH General Tech Oil Pump Woodruff Key Triumph 10
KVH General Tech Gaskets—Head/Oil Pump Triumph 4
S For Sale Oil Pump Rotor Assembly for Sale Triumph Classifieds 0
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
A T-Series MGTD oil pump bypass valve MG 0
MikeAH100M Oil Pump for BN2 Austin Healey 4
A T-Series Mgtd oil pump alterations MG 2
nichola TR6 Oil pump drive barely engages Triumph 2
S TR6 After I put in my new oil pump.... Triumph 3
S T-Series oil pump MG 0
svtmikey GT6 Oil Pump replacement Triumph 5
D TR2/3/3A Oil pump question Triumph 31
J TR2/3/3A Oil Pump Wear Triumph 5
H For Sale Healey oil pump drive Austin Healey Classifieds 0
B TR2/3/3A Oil pump rebuild Triumph 4
Michael Oritt 100 Oil Pump--options and resources Austin Healey 12
Michael Oritt 100 oil pump Austin Healey 5
J Bj8 Oil Pump Austin Healey 2
J 3000 bj8 Oil Pump Austin Healey 38
Jim_Gruber Priming oil pump Spridgets 9
JPSmit Question One - oil pump Spridgets 2
F Video showing oil pump and Kingpin bushing repacement on BJ8 Austin Healey 3
JPSmit New Oil Pump startup Spridgets 8
Rut 1275 oil pump, camshaft adapter Spridgets 2
gbtr6 TR6 Prime oil pump in rebuilt engine... Triumph 10
T TR2/3/3A Oil Pump Grief Triumph 8
D Not another oil pump question. Austin Healey 7
tinman58 TR5/TR250 OIL PUMP Priming Triumph 3
B Overdrive Oil Pump Installation Question Austin Healey 10
J Denis Welch Aluminum Sump and H/C Oil Pump clearance Austin Healey 18
dcoplan I've got a twisted camshaft-to-oil pump pin. How to fix?? Spridgets 1
BOBBYR oil pump choice Austin Healey 5
RJS TR4/4A Oil leak at/on fuel pump Triumph 7
D Wedge Funny oil pump Triumph 9
johnrip Wedge TR7 Oil Pump Leak Triumph 2
JPSmit Oil Pump Question Spridgets 13
B TR2/3/3A oil pump drive shaft removal challenge on TR3 Triumph 14
Patrick67BJ8 Oil Pump Recommendation[s] for BJ8 Austin Healey 12
M Healey 100-4 Oil Pump Condition Check Austin Healey 3
BillW103 Oil Pump Spridgets 24
TulsaFred Oil pump priming access Spridgets 8
richberman Anyone rebuild oil pump gears Austin Healey 1
johnrip Wedge tr7 oil pump leak Triumph 2
B Oil Pump for 100-4 Austin Healey 2
chrpark MOWOG oil pump cover- attachment to back plate? Spridgets 6
richberman Which oil pump? Austin Healey 1
P T-Series Looking for TD Oil Pump Top/Cap MG 0
johnrip Wedge TR7 oil pump Triumph 2
bill_powell Oil Pump Failure? Spridgets 14
